Syncing a P990i with Mac OSX
3 replies · 2,803 views · Started 08 June 2007
I have been trawling the web for months trying to find a solution to this problem. I am running Mac OSX and have found a program to pull and push my calendar via bluetooth, I can send contact via bluetooth and I can finally copy across music using SyncTunes (strangely no m3u playlists). This is a long and drawn out process and this does not take into consideration video. So my question is anyone aware of a standalone program that can do this all, specifically for the P990i
Thanks for your help
Ricky
damo86 wrote:simple answer..no!
theres isync support coming when the p1i is launched
Thanks for the information, can you provide some links to information on future isync support?
