Nokia N95 Technical Specifications
2 replies · 2,214 views · Started 09 June 2007
General
Operating Frequency
* WCDMA2100 (HSDPA), EGSM900, GSM850/1800/1900 MHz (EGPRS)
* Automatic switching between bands and modes
Dimensions
* Volume: 90 cc
* Weight: 120 g
* Length: 99 mm
* Width: 53 mm
* Thickness (max): 21 mm
Memory Functions
* Up to 160 MB* internal dynamic memory for messages, ringing tones, images, video clips, calendar notes, to-do list and applications
* Memory card slot supporting up to 2 GB microSD memory cards
* Changes to product details are possible without prior notice. Application offering may vary. Dynamic memory means that the available memory is shared between dynamic memory functions. When any of these functions is used, there is less available memory for other functions which are also dependent on dynamic memory.
Power Management
* Battery: Nokia Battery (BL-5F) 950mAH
* Talk time: up to 160 min (WCDMA), up to 240 min (GSM)*
* Stand-by time: up to 200 hours (WCDMA), up to 225 hours (GSM)*
* Operation times may vary depending on radio access technology used, operator network configuration and usage.
Displays
* Large 2.6" QVGA (240 x 320 pixels) TFT display with ambient light detector and up to 16 million colors
User Interface
* Operating system: S60 software on Symbian OS
* User Interface: S60 3rd edition
* Dedicated Media Keys
* Multimedia Menu
* Active standby screen
Call Management
* Contacts: advanced contacts database with support for multiple phone and e-mail details per entry, also supports thumbnail pictures and groups
* Speed dialing
* Logs: keeps lists of your dialed, received, and missed calls
* Automatic redial
* Automatic answer (works with compatible headset or car kit only)
* Supports fixed dialing number, which allows calls only to predefined numbers
* Conference call
* Nokia Push to talk (PoC)
Voice Features
* Speaker independent name dialing (SIND)
* Voice commands
* Voice recorder
* Talking ringtone
* Integrated hands-free speaker
N-Series BLOG
nokia-nseries-phone.blogspot.com
