N95 Back Cover Change
9 replies · 11,657 views · Started 09 June 2007
iv changed mine frm plum to sand, its so easy, just remove battary and cover and them grip the back part where it folds over to the keypad and prise it off, its only stuck on by 6 sticky pads
yer ive seen it looks liek its just clipped, do u get new sticky pads witht the replace ment covers n is it easy to swap the lens cover.
think i might get the graphite one , aint seen the sand one proporly yet
yes i got the 6 sticky pads with my sand cover, i ordered mine from blueunplugged.com, u have to order the parts seperatly, the back cover, the battery cover and the memory card door, it cost me �21 including p&p, not sure about changing the lense cover tho, i wudnt try it
Biggzy wrote:yes i got the 6 sticky pads with my sand cover, i ordered mine from blueunplugged.com, u have to order the parts seperatly, the back cover, the battery cover and the memory card door, it cost me �21 including p&p, not sure about changing the lense cover tho, i wudnt try it
You dont have to order everything seperately.
I got the graphite battery door and the houseing which already had the micro SD door attached to it and the sticky pads already on the inside with a strip of plastic over them which peels off to expose the stickyness.
mr g wrote:You dont have to order everything seperately.
i had to order the battery door and the main back part seperatly as they didnt come togeather.
Biggzy wrote:i had to order the battery door and the main back part seperatly as they didnt come togeather.
Yeah i had to as well,but the stickers and the door came with the houseing.
