SE has finally upgraded PC Suite to a version compatible with Windows Vista. Go to Sonyericsson.com for PC Suite for Smartphones 1.3.19:
P990 Vista compatibility at last!
I got the new pc suite installed fine, but when i connect my p990i to the machine via usb. Vista asks for drivers for the cable, i have searched for these drivers and they are nowhere to be found. Also had a look on the disk SE sent with the phone and no luck.
Does anyone know where i can get these drivers from ?
After a long wait....IT WORKS!
All you need to do is when installing the new PC Suite from SE tell it to NOT install the Network Wizard. Then install the Suite, connect your phone and TADA!
