Have just downloaded and installed the new Nokia Nseries PC suite. Maybe I'm having a blonde moment but I don't see a programme for downloading images as there is on the 6.83 PC suite.:con?
Nseries PC suite
No there isn't - crap isn't it? Just installed it myself this morning. Had to use mass storage and manually find the photos 😞
millski wrote:No there isn't - crap isn't it? Just installed it myself this morning. Had to use mass storage and manually find the photos 😞
I think it's done under Single Click Sync. If you right click on it there are some basic settings. I then looked in My Documents and found a folder labelled NokiaLifeBlogData > Files > Datastore. It had saved my images there as well as SMS and MMS.
I don't use lifeblog, so I didn't install it this time - it annoys me...
