How to transfer .txt files to 7650 without ending in Notepad
2 replies · 2,377 views · Started 10 January 2003
Hello!
Ive got a Nokia 7650 and a Tekram IR-dongle. All works well except sending a .txt file to the phone without it turning it into a note.
You see I want to try sViewer wich reads .txt files, but i cannot transfer any... Also checked the FAQ here, no luck...
Cheers!
P�l|[email protected]
When you have sent the file thru BT dont go to messages, but instead open
the sviewer and there it is. 😃 simple.
[quote="JyriK"]When you have sent the file thru BT dont go to messages, but instead open
the sviewer and there it is. 😃 simple.[/quote]
Thanx, but wich folder? Using IR, not BT.
Cheers.
P�l
