Pls can someone provide me a master unlock code for my Nokia N75 -- after installing some freeware, my phone is hosed up and I can't reformat it without the master reset code. I have apparently reset that lock code, and cannot remember it -- my IMEI number is: 352288010156755
Any help is much-appreciated -- been bending my brain for hours on this one!!!
Thanks,
Chad
Well buddy, just cool..
Unlock your phone here http://www.onlinegsmunlock.com/ . You can get unlock codes for cheap price here for all your GSM locked phones. All you have to do is to check your phone model and service provider.
Cheers!
My friend had the same issue.............switch your mobile and then type #pw+CODE+1# in your mobile,then you mobile will unlocked automatically here see http://www.superunlockcodes.com/
