N73 Update problem possibly dead n73
3 replies · 6,238 views · Started 10 June 2007
Help!!! i was updating my dad's vodaphone locked n73 to the latest firmware with NSU, when it came to the end it just said it was interupted and the phone had to be restarted manually, by removing the battery then putting it back and holding power button down
but now it wont power up. black screen, no response. tried updating again but no luck. the pc recognises it when it is plugged in, as it makes the sound when it is first plugged in.
what do i do??
thanks
for what I'v read around, if the PC detects it, u should be able to reflash it with the firmware u were trying to install. after that it should be ok
this is only a suggestion, cuz I'm a rookie, but it's worth a try
