Hi everyone,
I want to kno which program i shud use to make the incomin call display picture larger than the default one! its too small! Thanks ppl!
Hi everyone,
Why don't you try doing a Google search for "incoming call display picture symbian s60 v3" and you might get lucky. The first result for example here gives you what you're after.
As an added bonus, it would have taken less typing than your post.
Use Skycaller pro (let's U use pictures or videos 4 in or outgoing calls or messages)
Or use Fscaller (basicually the same but the first one is better)..
You can buy it or do a search on sites 4 a c......d version
regards
