Just had my N95 repaired vis Vodafone. The slider issue sorted in 48hrs..impressed really.
However since it came back and I resorted the backup. I can hear nothing via the phone earpiece (loudspeaker works). Once or twice it worked then nothing.
I assumed it was damaged in the repair process but checked all the settings just in case.
Under general - enhancement it shows headset default ? is this correct and if not which of the options should it be on ? BTW I have never used a headset since purchase.
Tried a soft reset but the setting remains.
Any ideas
Hello Alastairg, yes the setting is default. So that is correct. As for the rest of the proble I cannot help you with that, sorry
Thanks so back it goes again although vodafone claim it can be fixed via firmware update ????????? I will try that but cannot see how. This has all the hallmarks of a hardware fault.
Just talked to local nokia service centre. 'Just bring it in and we will update the firmware..well known fault' Can I do it I asked No we need to do it ??
So I updated the firmware this evening. No problems to V11.0.026 but you guessed still not sorted.
Any ideas :con?
