N95 no display on screen :(
1 replies · 6,073 views · Started 11 June 2007
All of a sudden my N95's lcd has stopped working.
ive turned it off, charged over night, plugged into pc and everything seems to work apart from the stupid screen.
it occassionally decides to work then switches off again not long after.
anyone got any ideas on this please? or possible quick fixes without it having to go away.
onto your PC .. then hard reset .. Green * 3 while switching on .. try using it that way for a short time .. if its ok then it may just have been a rogue setting someplace .. if not then sorry you have a hardware fault ... and it'll need service at a minimum .. the plus is yu already have your system backed up 😊
