Despite the referring to Nokia's non-support, I can't understand how allaboutsymbian can speak with such certainty. OK, Sandisk has confirmed that its 4GB microSDHC is compatible with N95, but along with a footnote of "Based on SanDisk internal testing". With which firmware they tested? Who knows? As most of you know Nokia released a firmware update, and it might have precluded the use of microSDHC. Who knows?? You might think that I am creating some sort of conspiracy theory, but we cannot know whether Nokia is considering to release a device in the short term which would be compatible with microSDHC, whereas worse than N95 on some other respects, so that as a sales strategy they may put its consumers to a compelling position, scaling the cons and pros between that device and N95. Doesn't this always happen??? Also don't forget that, if you run the presentation of N95, you will notice that it says that it is compatible with microSDs that are up to 2GB, which is in accordance with the device's specifications posted in official websites of Nokia.
I think there is another issue which needs to be discussed! The manufacturer's of SDHCs + the SD Association itself claims that regular SD cards are manufactured up to 2GB. What about Samsung's announcement in May 2007 in which they say they created 8GB microSD cards, and they are planing to ship it in 2008??
I wanna draw your attention to something at this point. The manual of my Sony DSC-G1 camera says that the device is compatible with up to 8GB Memory Stick Pro Duo (though Memory Stick Pro Duo can be manufactured up to 32GB, as far as I know) As you can see there is a limit.
In this respect, if we assume that N95 would be really compatible with Sandisk's 4GB microSDHC and Samsung's 8GB microSD and that it is not compatible with a greater size of both microSDHC and microSD, which one would you prefer???
Another issue is that, microSDHC's are going to be released with Class codes of 2, 4, 6 according to their speeds. I am not an expert of this stuff, but I am wondering whether the Class codes would be an issue in terms of compatibility to N95. For instance, Kingmax is also considering to release a 4GB microSDHC soon, but unlike Sandisk, which is going to release a Class 2 microSDHC, it is going to release a Class 6 microSDHC.
Aside from the afore-mentioned things, unless mymemory.co.uk changed their website upon noticing their mistake after reading allaboutsymbians's posting, it is a shame for allaboutsymbian that they informed that the item is currently in stocks of mymemory.co.uk. In their website it is clearly seen that the item can be only pre-ordered. The sadder part is that the image posted in mymemory.co.uk does not even bear a company's name or similar sign or information. I highly doubt the information given in mymemory.co.uk's website.
Shortly, if I were you, I would be weary against the highly expected microSDHCs in terms of their compatibility to your N95. As you can see, this issue is much more surprising than you think! (Who could expect that; in an environment where the manufacturer's of microSDHCs and even the SD card Association, which determined the specifications of these flash memory cards, excitingly say that regular microSDs can only be manufactured up to 8GB; a company would come up with a 4 times higher capacity 8GB microSD???)
