PMitchell wrote:But be aware that WEP is not secure in any way. It is as good (or bad) as an open wlan, really.
Really this is being overplayed on this forum.
It provides *moderate security* - security, that if you live in a fairly rural setting, or are not surrounded by lots of other WLANS in the area is probably 'good enough'.
It can be hacked (but then so also can WPA), but then you could also be the subject of a spoof email/phishing attack from something that looks like it's from your bank etc, or someone could rifle through your bins and commit ID theft, or you could go out on the street and be mugged tomorrow. The point of all of this is that yes there is a risk, but cracking WEP can still takes knowledge - and isn't something that the vast majority of every day users would know how to do.
People who say things like this are often perfectly happy to use the same password for all of their online banking and credit card payments etc. and these passwords are often infinitely less secure than any 128 Bit WEP key will ever be.
Yes it is certainly preferable if you can use WPA (or better), but the problem that has been pointed out before is that the N95 often does not work very well with WPA and certain routers.
So you have to make a choice between having *moderate security*, or no security at all.
WEP will certainly in most cases stop your neighbours from leeching off of your wireless network - although it is unlikely to stop a determined hacker from doing the same. But again, the question that arises and one that you need to answer for yourself, is realistically, just how many hardcore hackers (or just general geek types) do you have living within a 100 or so feet of you, or how many people do you know who would be prepared to park up outside your door, day in and day out, just to use your wireless network?
There is certainly a risk that someone might, but people on the whole aren't always very good at assessing this risk.
Anyway I do think this statement is inaccurate. WEP, although not ideal, still provides considerably *better than nothing* security.
Either that, or possibly just learn to put up with the idea of not using WLAN on your N95 at all.
