N95 active standby customizations?
3 replies · 2,804 views · Started 12 June 2007
Just wondering, is it possible on the home screen to add new options to the list, other than the calender and wifi thingy? For example, could it be set up to have a missed calls or messages/email option on the list?
Short answer - No. Longer answer can be found by searching through the various posts on the subject. Nokia have restricted the Active Standby screen - what you see is what you get. The only customisation is the list of program icon shortcuts across the top.
Its all or nothing pretty much:frown:
I found a progam that lets you choose what you have on the main menu but it wasn't for the N95😡
Its a really great feature and would be great for the N95, and the lack of it was one of my main annoyances with the phone.
