Hi All,
I have a problem with my new N95, I have downloaded the Smart2go software for the phone, it all goes well I accept to install the software and towards the end it comes up and says UPDATE ERROR.
How can I get the smart2go software to install
Cheers
Should install without any problem... Is the smart2go software or the maps that cause the problem?
Hi
I assume you're trying to install smart2go onto the N95.
Don't.
There's a version of smart2go already on the phone, called Maps. You can download smart2go mapping information (that is, the maps themselves) and add them to the phone, but, as you've found, the application doesn't like being installed twice.
