Headphones work fine, plugged via AD-43 or directly in 3.5 mm jack, but remote control buttons doesn't give any sign of life. Any suggestion?
AD_43 controller
Have you got the hold switch in the right position?
(Just a thought...)
Assuming it's not the hold switch, you probably have a faulty headset then. My first one was like that too, but when I replaced my N95 (due to loose slider) the new headset worked fine.
I'd suggest just get in touch with whoever you bought it from and ask for a replacement.
robgreb wrote:Have you got the hold switch in the right position?(Just a thought...)
Yes I have...
