Fring=free yeh?
1 replies · 1,453 views · Started 12 June 2007
Just wanna check. Its a new contract am am freaking bout incuring insane charges. Am using a wifi connection in offline mode, so no im safe. But what about when im not in offline mode? Whats fring doing then? I've exited the program so it should be dormant but wanna be sure! Lol im obssesive i know!
When you load Fring it should say it's connecting so you will know it's then costing you.
If you notice two solid lines with arrows on them under your reception signal then you will know you are still connected. Dotted lines, (if you indeed get them) will indicate you are dissconnected.
The fail safe is to hold the red button down as this will close all connections, so if in doubt just do this to make sure. :icon14:
