I'm new to all this memory card business and I've been reading the Sandisk website regarding their 2Gb Micro SD cards.
I've narrowed it down two: Micro SD Premier and Micro SD Ultra II
On the webiste both are referred to as high speed....but which one is best for the N95?
I'm a bit confused as they seem alike in specification.:con?
Can some more experienced people enlighten me?:icon14:
Thanks,
M
I've got a normal speed card and think it's fine, so my oponion would be that either of the ones you mention would be fine... 😊
Thanks for your reply. There's only a few pounds in price difference...does anyone know which is better of these two? or is it just marketing hype?
I'm only going to get one 2Gb card so I'd like it to be a good one. 😊
Thanks,
M
Which is cheaper?
I've only ever heard of people talking about the Ultra - so maybe go for the one most people have?
mmh wrote:Hi,Thanks for your reply. There's only a few pounds in price difference...does anyone know which is better of these two? or is it just marketing hype?
Thanks,
M
I believe the difference is in read/write speeds:-
Non UltraII MicroSD cards only read/write at 4.5Mb/sec.
UltraII MicroSD cards read/write at 9Mb/sec
