Dead N70
2 replies · 2,170 views · Started 13 June 2007
Ive a 5 month old Nokia N70 and it seems that the phone is dead.
When i switch on the phone, the screen becomes bright white, then after a couple of seconds, the start up sound is played and the light becomes a bit dimmer.
Then nothing, no color, text and no usb connection.
When i did the green,*,3, power combination, nothing happens, the screen remains white...
Can somebody please help me, i so desperate....:frown: :frown:
It is quite obvious that your phone is not dead yet. So nothing to worry. Try that combination again, but this time follow this sequence:
Try the green/3/* thing again (until you get it to work).
- Turn off PIN code requests.
- Charge the phone fully.
- Turn off the phone.
- Remove the memory card (not really needed, but I usually do it to be on the safe side).
- Put the phone on a table (easier to press the keys then, in my opinion).
- Press the three keys and keep them securely down and do not release.
- While the keys are still down, turn the power on.
- Do not release the three keys until you see the prompt for the home city.
