Contacts - List by 'Business' not possible!?
0 replies · 1,593 views · Started 13 June 2007
This should be such a simple thing to do but can I can figure it out - no ?! I like to think of myself as a competent PC & N95 user but this has been tormenting me for a while now so hopefuly somebody out there can help.
I'm syncing my MS Outlook contacts with my N95 without problem, however:-
Whenever I view the contacts on the N95 they are all listed by 1st & 2nd name. Problem is I have a lot of business contacts and its the Business Name that I need to have listed. Is there any setting that allows you to show business name first in the N95 contacts list ?
The only time business name does appear on N95 is when the contact name field is left blank.
Ideal would be to have contacts listed with the following name field priorities;
Business Name
1st Name
2nd Name (although not so concerned anout this)
In Outlook I have all my contacts listed by business name and this works fine - it's only on the N95 I have the problem.
If the Nokia software can't do it any good 3rd party products to reccomend ?
