I'm trying to configure outgoing server mail to send mail but I can not configure outgoing port to use 4 digits. My email server uses 1025 smtp port.
I read recently some information about limitation of E61 to use 4 digits configuration port.
Someone can confirm that? Any suggestions ?
Regards
jbottcher wrote:I read recently some information about limitation of E61 to use 4 digits configuration port. Someone can confirm that? Any suggestions ?
Yes it's another dumb bug/limitation. Since I run my own mailserver I set it to use a 3 digit port number.
I just bought a Nokia N73 ME and I've got the same problem too, i was just wondering if anyone has found a solution to the problem?
LasseFJ wrote:I just bought a Nokia N73 ME and I've got the same problem too, i was just wondering if anyone has found a solution to the problem?
There are no solutions except complain to Nokia.
There has to be a solution??
LasseFJ wrote:There has to be a solution??
As I have said the only solution is for Nokia to fix it. I can't understand wtf they limit it to 3-digit port numbers, everyone knows that there are ~256^2 possible ports, which works out to ~65000 ports. In both cases storing a 3-digit decimal number or a 5-digit decimal in binary only uses 2 bytes, so Nokia aren't saving any memory by making such an asinine restriction.
The workarounds are:
1) as mentioned before, run your own mailserver
2) use an ssh tunnel to act as a proxy for your mailserver
Thank you for the reply 😊
