Software
8 replies · 2,624 views · Started 14 June 2007
I just thought i would start a thread for people to say what software they have, whats compatible etc and what themes yo have
i have
spot-on
TomTom 6
Y-brower
alienware theme. its the best ive come across
still searching for more apps.
So come on guys what do you have on your N95
Calcium
Fring
Gmail Mobile
ifinfo
mobireader
sportstracker
truphone
metro
btwebcamera
rescophotoviewer
3D game engine example
glbenchmark
shozu
widsets
karmaresh15, with all (every single one so far) posts of yours only for advertising this RSS reader, is it your own or your company's application, which you're "covertly" trying to promote?
For others: There's a free built-in RSS reader on all S60 3rd Edition phones. Namely, the web browser supports also RSS feeds.
Mobile weather ubahnstation.net/projects/mweather/
I had to uninstall 1.1 and then install 1.0 and upgrade to 1.1 to get it to work. It now works great and very usefully too, plus its free!
Nav4all nav4all.com
Works with onboard gps and its free bar the data charges
mIRGGI mirggi.jutut.fi/article/1553
Irc client, again free and although a tad buggy it works, 
PuTTY s2putty.sourceforge.net/
THE ssh client, again free and invaluable
Also installed are Truphone and Fring
(sorry for weird addresses)
Wants
The ability to sync with thunderbird and lightning (simply).
That data entered in contacts is used in other apps like birthdays in calendar and lat long info in maps locations.
Hi all,
As the N95 is my second device and mainly used for Multimedia these are the apps i have installed after i had removed the Welcome and Demo Tour as well as the local search app that i can never understand why it has so many entries.
Nokia In Device Search
Nokia Podcasting
Handy Taskman
Fring
Mobile Weather
Screenshot
I may in the future install Handy Clock but am currently concerned of reports reoccurring alarms disable the Multimedia key which i use all the time, and Tom Tom 6 which i currently have on my E61 as the screen is better for Sat Nav IMO and i much prefer using TT6 and an external GPS receiver as i think it is a far superior to the inbuilt solution.
Marc
ajay_wilson wrote:I just thought i would start a thread for people to say what software they have, whats compatible etc and what themes yo have
i have
spot-on
TomTom 6
Y-brower
Where did you get the alienware theme from? Found one on the net but it reckons it's not supported??
i cant remember where i got it. i just searched n95 themes in google and it came off one of the top hits, i can email u the installers if u like
