Problem with no usb connection <<SOLVED>>
0 replies · 3,067 views · Started 14 June 2007
as many of you, i use my ngage for just everything, last use i gave was as a usb disk to load some drivers in a Centos installation, but i have a trouble during the install...resulting in a hot swap disconnection of my phone... wich coused the corruption of the MMC card and the consecuent loss of everything loaded...
but when i plugged the ngage to my laptop, there was nothing happening, no usb drive detected and then i started to worry... i formated the mmc card, with the ngage, but no change at all, then i reseted my phone (*#7370#), and nothing changed.... read some forums, giving recipes of install some software and change the "mbr" record of the mmc (�?), etc...
next day in my home, take my digital camera (Canon A 410) and put the formated mmc card, and i formated it again, selecting a low level format... just few second after my mmc card was formated... then put it on my ngage, plug the usb cable and voila!.. "new usb mass storage detected"..
i love the simple solutions to hard problems, and here i have gave you one finded by me...
regards, and keep playing in this spectacular machine!!
Victor from Chile
