help...were did my theme go?
7 replies · 1,578 views · Started 14 June 2007
hi newbe here, after downloading a theme to my comp, i put it on my phone via usb and all was ok.....but when i went to find it ,it was not there, i conected up my phone again via usb and opened the folder were i put it and it WAS there......................ANYONE KNOW WHAT IM DOING WRONG? I HAVE 3 THEMES ON THE PHONE NOW AND NONE OF THEM SHOW UP IN MY DATA FOLDER.............
Themes should be in the themes folder,or check your app manager as it may need to be installed from there.
Sorry i dont know much about this as i install mine manually via mass storage and not thew way you have done 😊
To be honest it shouldn't really matter but maybe you're transferring it to the phone memory image folder and then, on the phone, looking for it in the memory card folder, or vice versa.
Using the Nokia Phone Browser in PC Suite (you should see the icon in My Computer on your desktop) transfer the theme .sis by navigating to NOKIA N95 > MEMORY CARD > OTHERS then see if it's there on the phone.
Alternatively, with the phone connected, just double click on the theme file on your computer and let it install directly. There's not really any need to have the .sis file on the phone itself.
