N95 Camera Rotate Image Feature.
1 replies · 2,498 views · Started 14 June 2007
What does the N95 Camera Rotate Image Feature do, when enabled i dont seem to see any difference between it on or off image still taken same way.
Turn it off, then take two pictures of the same object, one in landscape and one in portrait. When you view the images in gallery, the one you took in portrait will be on its side. If you had had the setting enabled, it would be the right way up.
