i want sat nav/tom tom on my fone to direct me to places, wat do i do and wat are my first steps??? it would be better if its free :icon14: :icon14:
i want sat nav on my fone?
The built-in Maps app in the N95 does it already. If you want voice guidance, you can buy that service (with the built-in Maps app).
Instructions in the N95 user documentation (if you can't work it out by just playing with the app). See also http://www.smart2go.com
If you want TomTom, buy it from TomTom (http://www.tomtom.com).
cheers il give a go
You have other free alternatives, that seem to work with N95 internal antenna, like Nav4All and Amaze.
I wouldnt call those "free" considering that Nav4All is stated as being a limited free trial and both of them require you to download their maps over 3G or GPRS. In many countries, this is absolutely.. not free!
