Whats the best GPS software that actually works on the N95? with good UK maps?
GPS Software
"Best" is a relative/subjective term. Unless the built-in GPS software satisfies you, not many others have yet support for the built-in GPS module. I think Route66 is one of them that do.
Both nav4all.co.uk and amazegps.com work well with the internal gps on the N95 and they are both free. I'm currently testing navig8.wisepilot.com which is a commercial product with maps and it works well so far.
Copilot is the best by a long way. Almost as good as TomTom and better in some aspects.
I already saw Route66 work with internal antenna and is better then smart2go. If is the best, it depends from you. For me is real good!
nj7 wrote:I already saw Route66 work with internal antenna and is better then smart2go. If is the best, it depends from you. For me is real good!
I agree. For external GPS I rate TomTom but Route66 is nearly as good and the version I have works with the internal GPS so I use that most.
I'm using CoPilot and it's brilliant, far better than smart2go. Can't fault it.
Ok thanks alot, I think I'll go with Route66
chriscuk18 wrote:Ok thanks alot, I think I'll go with Route66
If you do, have a look at this thread, I have posted my findings on getting this working with the internal GPS:
http://www.allaboutsymbian.com/forum//forum/thread/60082/&page=5
