Voice tags not recognised
7 replies · 3,442 views · Started 15 June 2007
Hi
I'm having trouble getting my N73 ME upgrade to recognise voice tags.
I keep getting No Match Found.
The best I've had is when it will give me a different person's name!
I've tried it throught the headest but the same happens.
I upgraded the phone/firmware to the ME so is this a problem with the 3.0705.1.0.31 ME firmware?
I tried it a few times as a normal N73 and it seemed to work ok.
Anyone else had this issue?
Thanks.
Yup, definitely. Same on N70 and E70, for the same voice I get different numbers called, because of a Nokia genius whici decided that 3310's way to record voice was not good enough. Now is useless. Bravo Nokia, keep up the good work.
Neither of those. I own a E70 and the former phone was an N70. The problem is that all my contacts are normaly using nicknames instead of real names and that SIND moron cannot even pronounce them as it should. None of the phone worked and as I said, if I tell the idiot to call someone, I end by calling somebody else.
This is the case for many other phones. At least it would've been nice not to have it at all. The thing is that you can record your voice, but only to launch apps, but it's faster to go to menu and select it from there.
Post 4.0727.2.2.1 upgrade the voice recognition now works - was this mentioned in the changelog?
Still hit and miss with one-syllable names but on the whole it's an improvement.
I was fed up of calling Nomatch Found (does he work for Nokia?)
