Question re: webviewer and bluetooth connection
4 replies · 1,865 views · Started 11 January 2003
Hi all,
I've managed to get most apps working over a bluetooth connection to the PC thanks to the advice in this forum.
My only problem is that webviewer doesn't work. When I try to connect to my "lan" connection on the phone, it says "App.closed jes-12a-ConnectionsEventServer@1... KERN-EXEC 3". I've not come across this in any searchs on this forum, or any others.
Any ideas?
Thanks all.
Thanks for the suggestion, but that doesn't seem to work either. I don't get the error now, the GPRS G appears as it connectes, but Mrouter doesn't process any traffic.
TipicMe and Wireless IRC still work though, after changing the gateway IP to 0.0.0.0.
I don't understand it; why does everything else work, but not webviewer, when other people seem to have had MORE luck with webviewer!
Any more suggestions greatly appreciated.
Go to http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=6405 for a possible solution.
Christophe.
