hi there
i hope someone who is a lot smarter than me (won't take much), can help me out with installing tomtom 6 on my n95 (vodafone uk)
i've tried to install it in the usual way (by copying it to my memory card then installing it through the internal install) and it comes up with "certificate error contact application supplier", so i tried using pc suite and it comes up with the same responce
what i'm not getting is the "this programme is untusted, continue anyway " i have gotten with other nokia's when installing tomtom
is this a new verification thing nokia is using with the n95 or is it something else
thanks in advance for any helpful pointers that u guys (and gals) can give me
installing tomtom mobile 6
qwox wrote:hi there
i've tried to install it in the usual way (by copying it to my memory card then installing it through the internal install) and it comes up with "contact supplier", so i tried using pc suite and it comes up with the same responce
What version of Tomtom is it? You need to make sure its for series 60 version 3. Please try searching, there are many guides about Tomtom on here
it was tomtom v6.01.s60 but ive since downloaded tomtom mobile v6.02.s60v3symbianos9.1 and i'm still getting the same problem
qwox wrote:hi there
With Vodafone, you need to change some settings before you install it. Go to tools, application manager, options, then settings. Software installation needs to be set to "All". Online certificate check needs to be set to "Off". Now try to install it using the internal install on the phone. It should now work.
qwox wrote:hi there
PM me and I will make sure that U get the good version by mail......
