Does anyone know if the Wifi scaner thats on the front screen of the N80 can be removed from view and if so how do i do it.
Gary
Gary
I think if you just uninstall the WLAN wizard it will be removed.
I think is enough remove the stand-by mode...
yeah, if you uninstall the app it will probably leave the front screen.
Mine leaves intermittently, and launching wireless wizard puts it back.
This is interesting. My N80 does not have the wireless lan on the front screen.
All it shows are my standby items on 1 line and the calender items on the second line. I am using Firmware V4.0632.0.38
(Afraid to update to 4.07)
trendsbze wrote:This is interesting. My N80 does not have the wireless lan on the front screen.
in the bottom. Can't remember if it works for regular N80 or not..sorry 😞
Thanks for the info, but I was just curious as to why it wasn't on my N80IE screen like many others. I really don't want it there since I can easily access it in my connections. Anyway if one day I want it on my screen I will use your info.
i find the WLAN Wizard very useful, and i recommend it!
If its not showing on your main screen, then it may not be on the f/w. I was under the impression tho that it was avaialable to all f/w versions 4x.x.x upwards. and possibly the late v3's.
Anyway, if you launch the wireless wiz app see if it comes on the front screen... if it doesnt Id guess its not gonna work with your phone/ f/w.
It is useful tho... especially when roaming around the world/city whatever.
You can set the 'Show Availability" under tools >settings >conection > Wireless LAN
