Synchronise with MS Outlook
1 replies · 2,064 views · Started 15 June 2007
Hi, do you know if it is possible to synch the N95 with Microsoft Outlook, particularly the calander or does it use its own software?
Craig
craigmill wrote:Hi, do you know if it is possible to synch the N95 with Microsoft Outlook, particularly the calander or does it use its own software?
Craig
Install PC Suite from the CD that came with the phone. There is sync software included and its very good.
