hi, i wanted to know if there is a way to convert the chinese 3650 to english, if you could tell me i would really appreciate it
thanks
thanks
My guess is that you should have the english language pack installed and know some chinese 😃 so you can change the device's writing language.
Or you can take it to a local NSC,the should sort it out for you.
I'm not sure about this because i dont know what is 3650's status trough out the world because if i'm not mistaken its released only in china.
If you live in a country other than an Asia Pacific country you might have hard time with this.
