Hello,
after a few days i'll get the following errormessage then i'm booting my N95:
Prog.closed
(6396816) NssVacCHT
hread
DBMS2
What's that? Did somebody of you know about this errormessage or the prog that cause this problem?
Greetings from germany😊
No. It happens after some third part installation?
nj7 wrote:No. It happens after some third part installation?
Did youn know, what application did cause the errormessage?
Pit wrote:Hello,
Prog.closed
(6396816) NssVacCHT
hread
DBMS2
Suggest you do a hard reset of the handset... (but this will format the internal memory and lose all contacts, calendar, apps etc.)
1. Power off the N95
2. Hold down 3, * and GREEN buttons
3. Power on (whilst still holding the above three buttons)
4. wait 60 seconds (whilst still holding the above three buttons)
If this doesn't work, your N95 probably has a hardware fault and needs repaired.
