Folks.
Just got my N95 and quite impressed so far ... Loving the WIFI option ...
Anyway ...
I realise that Symbian does not have a task manager like windows CE, but I want to know how to get back to the top level any running application
eg.
I go to the applications menu and select TOMTOM and then while using that I miskey and it takes me to the media menu. without having to go back through the menu options and into applications to select TOMTOM again, is there an easy keystoke to cycle through running applications.
I guess it the same as if i was using windows I would just ALT-TAB to reselect the window to the foreground.
I tried loading a task manager, but that itself is just another running application that is buried by native options.
I have scoured the manual, but can't find the answer ?
regards
Justin.
