Nokia N95 and Nokia 800
2 replies · 1,600 views · Started 18 June 2007
Does the N95 work ok with the Nokia N800 internet tablet??
If yes, does it work out of the box or is setup difficult?
It works. Easiness is relative. It isn't very difficult (not any more so than with any other Bluetooth phone, I'd say).
depends what you mean by 'works' if you mean can you tether the two devices, use the N95 as a modem for the N800 to browse the web, then yes, and it's really easy, there's a dedicated wizard to setting it up built into the N800 and as long as you have your service provider details at hand, it takes about five minutes.
I regularly browse using the n800 with my N95 because of the bigger screen, it's great, we've got a post on how it's done over at the wom world: womworld.com/nseries/2007/05/22/moblogging-with-your-nseries-and-n800 the guy in the post actually did it with an N93, but it's actually exactly the same process with the N95, hope that helps 😊
