anyone know hot to get to this dir system/apps/ ?? on the n95?
directorys
You can't get to any protected system directories on the device with untrusted apps (apps that do not have the, so called, "AllFiles" privilege/capability).
No file manager has "AllFiles", and unless things change, no file manager is likely to get "AllFiles", either.
What is possible to see, you can see with apps like Y-Browser:
http://www.pushl.com/y_browser
found out how you do it, browse in mass storage mode with show hidden and system files enabled on explorer
That handles only the memory card. Same result, if you stick the card in an USB reader. Doesn't help you with internal phone memory.
