W950i theme folder?
2 replies · 10,180 views · Started 19 June 2007
Hi guys,
im trying to add some new themes in my fone but i dont know where i have to put the theme files in?
ive used swiss mgr but couldn't find the folder >.<
thanks...
hm, the way i do it is through bluetooth. i download the file on my computer and send it via bluetooth to my phone, and it then goes into My Inbox as a text message, and you can then VIEW the message and INSTALL/APPLY the theme that way.
im not sure how you do it hooked up via USB, but i think you should just be able to put it in any folder and open it up and install it
Hi there,
I just connect my W950i via USB, then use file manager on the PC and drop the theme files (usually .utz files) into the OTHER folder of either the Phone or Media memory.
Once there, go to the handset, run file manager and navigate to the OTHER folder on the device you decided to copy the files to.
You should see them in the list. select the first one, and after a short pause, you will recieve a preview of the theme and a prompt if you want to install the theme.
Once you have installed the themes, you can delete the files from the OTHER folder as they are installed to the phone memory somewhere else???
You should have the new themes installed and ready for selection via the 'Themes' option from Control Panel > Device.
Hope this helps.
Mark.
