Did anybody change the color of their N95?
7 replies · 3,211 views · Started 19 June 2007
By picking up the 3 cover pieces needed in their chosen color?
How was disassembly?
Purple is rubbery right? Is Warm graphite also rubbery?
steffi wrote:By picking up the 3 cover pieces needed in their chosen color?
I changed from purple to warm graphite ,and yes they are both rubbery.
Very easy to do and i'm very pleased with how it looks.
If you do purchase the parts,say from Blueunplugged just buy the battery door and the back houseing.Dont buy the micro sd card door or the stickers,as they come with the back houseing.Blueunplugged dont tell you that though.
i changed mine from plum to sand, plum is too popular lol, the sand 1 isnt rubbery thank the lord, i hated the feel of it, also got mine frm blueunplugged.com
Wow, thats just cruel. So people that are purchasing all the parts are actually getting 2 micro SD covers?
Darla wrote:Wow, thats just cruel. So people that are purchasing all the parts are actually getting 2 micro SD covers?
The way it looks on the site is that you need to buy everyting seperatly.
Clever or sly,or both!
Question for those that have changed the colour:
I've found that once phones has been opened once they can never quite be sealed property and have to be opened again every so often to clear out bits which find their way in and get trapped between the screen and the outer lens.
Is this any better or worse than 'normal' with the N95?
Halon wrote:Question for those that have changed the colour:
This is not the case for the N95 for 2 reasomns:
- there is no 'outer lens' on the N95
- for changing the backcover you do not have to open the front 😊
So, no worry here.
Regards,
PM
