I have tried the Oakley ROKR A2DP headsets with the N95 with some degree of success. Audio appears to drop for moments, but I have not tested for long enough to determine if this is a problem with N95 or some power saving mode which is interferring with it. The ROKR's do stream from an iPod with iCombi adapter OK though.
However, the ROKR appears to connect and use Headset profile so I can do voice dialling perfectly, but the key on the ROKR to answer a call doesnt appear to do anything when there is an incoming call. I can hear the call coming in through the headphones, but still have to answer the call by pressing the button on the N95.
The documentation says that the ROKR does support both Headset and Handsfree profiles, (according to the documentation the answer call button on the ROKR appears to be active only on the handsfree profile).
I just wondered if anyone has any experience of the ROKR or how the N95 would choose to use the Headset profile rather than the Handsfree profile.
Im guessing if its ever going to work, its something which is likely to be fixed in a firmware update to the N95, I am just curious, because the ROKR's are really good.
Regards
Rich
