Hi all,
I have just got my w950i and have now had a few days to play with it. There are a few things that I am keen to do and was wondering if anyone out there has solved these problems.
1. Getting the VPN to work: Every time I try to set up a new VPN, it comes back with the message "There is no policy registered".
2. Syncing multiple contacts folders: We use Outlook Business Contact Manager at work which has a separate contacts folder vs my personal folder. I can manually sync each of these individually but it would be good to be able to do them at the same time.
3. Ericsson Mobile Organizer: I have installed the Professional edition and it seems to connect OK but often comes up with an Application Closed error with reason code "KERN-EXEC", reason number 3.
Thanks,
Michael
