Hello I am coming from a WM6 smartphone and had active sync set up with my works 2003 ms exchange server- worked great hated the phone-
Is there a way to have my N95 set up- Please help.
Thanks in advance
Thanks in advance
Yes. Nokia has a "Mail for exchange" that is the equivalent of this. But unfortunately this does not work for the N series anymore. I have heard that people have hacked the later versions to work by preinstalling the old one first and then upgrading to the latest one in there afterwards.
The best alternative is to use Roadsync from Dataviz.. I'm on that now and its quite good, but costs $49 USD.. (Nokia one was free however)..
where did you find the posts on people hacking the old one?
hilz wrote:where did you find the posts on people hacking the old one?
Search this forum. It basically done by first installing v1.3, then configure and then sync (v1.3 can be installed but afterwards you're not able to open any e-mail items) and then upgrading/overwriting with v1.5 or 1.6 => you will then be able to open e-mail items again.
