hello my brother and I bought 2 new N95's his came with a clear screen protector -mine didnt - where can I get one that is sized for it-
Any recommendations?
I recommend the martin fields one from blueunplugged. It's easy to fit, invisible once on and can even be removed, washed and then reused!
I would also recommend the Brando UltraClear. It is invisible, but it protects your screen. You can get it on eBay, depends, where you live.
Regards,
PM
When applying screen protectors make sure the screen is 100% clean its a bitch to apply especially if you get air bubbles. I wish Nokia had applied it like on their previous phones automatically e.g. 6600 and 6680 already had plastic covers.
I strongly agree with Quakester2000. I even take the top cover away on the n95 when I apply screen protectors, because you never get the edges 100% clean...
If the phone is not brand new (and I mean NEVER been in a pocket), take the top cover away by removing the 4 screws, clean it like mad, put it back on and then apply the screen protector 😊
