Golf Pro Contest Nokia e61i
3 replies · 3,137 views · Started 20 June 2007
Golf Pro Contest is a free download from Nokia as one of the e61i applications. After installing it, I get the message that the application is not compatible with the phone.
Any suggestion to get it working?
Thanks,
Paolo Bolzoni
bolzoni wrote:Golf Pro Contest is a free download from Nokia as one of the e61i applications. After installing it, I get the message that the application is not compatible with the phone.
Thanks,
Paolo Bolzoni
Same here. There's an E61i-compatible one available through Download! though.... works fine here.
Steve
Hey there buddy...i am sorry..but i tend to agree with the other guys..thats it wrks absolutely fine on my E61i too....
1. The Golf Pro Contest comes with the MC provided with the E61i when you buy it...so installation cant be a problem...
2. If you download the same from a Nokia site...there shouldnt be a problem at all again...
3. However if you have downloaded it from somewhere else, then you cn try this...see it it works
go to the application manager
then click settings
in settings you have, online certifcate check.....if it is ON...change it to OFF...
Now try installing...and see it works....
it it doesnt...then i amm sorry...cant think of anything else....
