N70 questions
1 replies · 1,201 views · Started 20 June 2007
Hello all,
Some days back i got N70ME. Nice phone. But have some queries reg. the same.
I got some songs bundled in the phone, but when i try to play, it gives some protection error. May be DRM error. Nokia shud've provided them unlocked....So from where to obtain DRM license for them?
Secondly, there're many applications in the phone still to be installed. Eg. Opera, Adobe, Norton etc. When i clicked them, initially they behave like setups n starts installation, n further like applications. But i want their SETUP 'sis' files, where can i find it? B'coz if i format my memory, i'll need them to install again.
Also, during any software install, it says i've 710MB free on Mem card, but i view it via Tools, memory details, it says 684MB Free. which one is true value? And is this normal issue? If no, then how to solve it.
I need to back up my MEM Card [sms, applications, system files/dirs etc all] and format it completely and then restore the backup as it was. So, how to do the same. Any software?
Plz help on all above matters.
Thx
Well, grab FExplorer from www.gosymbian.com and search for the sis files. Note that they must not be in C or E:\System\Install.
Never noticed the memory issue, I never used the menu option, only FExplorer.
For backing up data, go to Memory - Options - Backup phone mem.
