Hi guys just got a w950i on 3, can it be used with the SEUS? i know it has its own branded firmware but can it be uptodate with those that are unbranded?
whats the latest firmware available if not? is it buggy or ok?�
thanks
mat
thanks
mat
Don't see why not. It should pick up the CDA of your phone and then present you with the latest firmware assuming your phone doesn't already have it.
lemat1 wrote:Hi guys just got a w950i on 3, can it be used with the SEUS? i know it has its own branded firmware but can it be uptodate with those that are unbranded?
whats the latest firmware available if not? is it buggy or ok?çthanks
mat
Yes, you can use SEUS to update firmware if there are any newer available for your branded device. How to check? => Simply run SEUS on your computer and follow instructions.
Also a list with the latest "known" firmware for each CDA can be found here (it's maintained by "us users" on the internet so it's not allways up to date though):
http://uiq3.sourceforge.net/wiki/index.php/CDA/W950i
You have to check the row with CDA corresponding to the one on your device. Don't know which? => From man screen select 'More' => 'Status'.
