Are any docks available that connect to your PC to sync, charge, and possibly video/audio out for N95?
N95 Dock
Short answer = No
Longer answer = There are docks which will charge the phone AND a spare battery but i've not seen one which also syncs. Seems a shame cos if they'd just included the connected on the base and at the back it's be aeasy to hook that up to a usb cable. As for output to the tv, you can still access the multi-use 3.5mm jack on the left side when its docked so you sould just connect up the tv out cable as normal.
