I used to have a few apps installed on memory card, now i have a new N95 i put the card in and it says installing, not everything installs though, how do i get rid of this installing message?
Installing from memory card?
You'll need to connect the phone in Mass Storage Mode or put the card straight into your computer's card slot then find the apps causing the problem and delete them. Which can be easier said than done I'm afraid.
There are one or two threads on the N80 board describing how to do this more fully.
srw985 wrote:I used to have a few apps installed on memory card, now i have a new N95 i put the card in and it says installing, not everything installs though, how do i get rid of this installing message?
You can do this on the handset itself (without a PC and mass storage mode)
Go into Tools -> Application Manager then Uninstall any apps which are listed as Not Installed.
It takes ages as App Manager is really slow but this will do the trick.
