I have just bought a nokia 9210 .. earlier i was using the 9110i ... with the pc suit of 9110i i could easily add contacts on the pc and the update it on the phone .. but with the new 9210 .. i cant find that option on the pc suit or administrative suit i have the text file exported from there but i dono how to update it on the 9210 .... i tried using the "data mover" software that comes with the 9210 .. but everytime i try to use it it says "Note" Not found ... i removed it and then re-install it .. but didnt work .. i formated the device the memory card .... and then re installed it ... but it still didnt work along with that the internet startup gives the same message despite removing and reinstalling ... can anyone help ..
Data Mover !!!! Help! !!!
Go here to download the upgrade software, (I think it appears in the PC Suite or you will see it when you go to Start > Programs > PC Suite or Nokia.
Link
http://www.nokia.com/cda1/0,1080,1910,00.html
Download the guide.
OR
you can do it with the two phones via infrared, in Extras on 9210 provided the Software is installed.
N
here you wil find the solution read it in english by pressing on the english flag
http://www.aikon.ch/reviews/sw_review.php3?softwareid=199
well .. the solution u gave me is not in english .. tell me do i have to install all memory card data to get it working coz out of the memory card i have just installed mover ....
Data import
back to the overview
Review provides of: Colin to 06.02.2002 and since that time 1572 time called!
Price approx.: Freeware
Version: 3.01
Language: DE (if on German available here DE stands)
Admitted problems: The data are not with 9110 on the MMC fold the import !
Problems with other programs: -
Evaluation/opinion: The program functioned really very well and fast, naturally certain things must be still adapted, how the internal entrance wants, except one further with 9`600 Baud surfen?!?
Special: Contain ONLY in All_memory_card_data.sis!
Memory consumption during enterprise: approx. 250 KB
Alternative one: -
Left to the software: 9210 Download
9210 i Download
Nokia
The program is briefly the whole after that starts already absolutely self-describing and functioned really as simply as here described.....
Under options can to be now selected which data exactly to be imported be supposed, thereby is important evenly which one the data on that 9110 in the internal memory and not on the MMC has, which shifts data if necessary more vorhher again!
Also InterNet attitudes etc. can be imported....
Afterwards on connecting and with 9110 clicks simply the infrared connection activates and already begins the transfer....
Result: Who has 9110 around this program will be grateful, the data can naturally also via PC is made, however it goes owing to this program within fewer minutes!!
User Comment (write)
Zerweck Robert
23.03.2002
19:00 o'clock The program is really sharpens. Unfortunate I find only that I mean 800 stored SMS of 9110 did not rueberretten can. Does someone know a solution? Greeting Roby
Left to this Review by email send
Sender name: Email of the receiver:
9210 index
� by Colin Joerg , first version: 06.02.2002/last update of this side: 04.12.2002
http://www.nokia.com/nokia/0,5184,2034,00.html?applicationId=274&prodSupAppID=1&productId=49&categoryId=13&languageId=13
use the user guide this will help you is in the pack of the 9210
well well .. it finally worked ..... before that when i formated the memory card .. i just installed the mover .. and it didnt work .. i tried removing and re installing didnt work .. and today i tried to install all memory car data and it wouldnt work .. used to discnect teh device in the middle.. and guess what finally what worked was that i was installing it with the flip open and when i closed the flip and tried it installed .. and everything started working ... anyways ..thank you all for helping me .. it is great here
Wow,what a strange thing! Didn't know you should keep the flip closed...
well technology sometimes act strange ...
Yes indeed... :P
