Problem with the new Map Loader
5 replies · 3,640 views · Started 21 June 2007
I'm having problems getting the new version of the Noka Map Loader (version 1.1)
When I run it, it complains with an error message
"An unexpected error occurred, Try again. Sorry for the inconvenience"
Has anyone else managed to solve this?
mr g wrote:Wait for the new FW mate as the new version of Nokia Maps will be with it.
Thinks he is talking about the Nokia Maploader not Nokia maps. You can try and get hold of the old version of Nokiamap loader maybe more stable. Its version 1.0-w7.02
I've had the same problem on my home PC. When I ran the map loader on another PC it worked perfectly and I was able to load the maps onto the N95 without problems.
It must be something to do with PC hardware, or config.
MartyMcr wrote:I'm having problems getting the new version of the Noka Map Loader (version 1.1)
TEMPORARILY disable your Firewall and Virus-Checker.
Some Nokia SW is blocked by some Security products.
